runs better colder
Old Feb 4, 2009 | 09:16 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
runs better colder
I'm at sea level and the colder it gets, the better it runs from start up to accelleration to cruising. Like today hovering at 32F degrees. It's a stock LG4 with rebuilt carb basically tuned to factory specs. Any thoughts on why or maybe offers from Greenland?
Old Feb 6, 2009 | 12:14 AM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: runs better colder
Cold air is more dense = more air going through your engine = more power.
Old Feb 6, 2009 | 12:48 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Are you implying it runs poorly when its warm? Or ok warm, better cold?
Old Feb 6, 2009 | 05:43 AM
scooter500's Avatar
Car: 87 Camaro Z-28
it runs ok when its warm outside. once warmed up on a day that 50F or higher then RPMs drop to factory specs where I'm aiming for. That's about 550 idle when in sitting at a light drive. this morning's commute will be about 23F and the idle is going to probably settle at 700 rpm. My thoughts are to just make tuning adjustments when it's about 60F. vacuum is looks to be constant at idle hot or cold day at a hair under 15. it's a stock set-up.
Old Feb 6, 2009 | 07:34 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
adjust the idle air screws when it is warmed up
Old Feb 6, 2009 | 05:52 PM
scooter500's Avatar
Car: 87 Camaro Z-28
I'll check it out
Old Feb 14, 2009 | 09:16 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Turned out to be a bent hanger. ~50F degrees today, so made small curb idle adjustment & checked dwell.. running rich ~25degrees on 6 cyl scale. thought I'd mess with that later & check secondaries (have been trying different hanger/rod combos for fuel economy). saw that the hanger was bent so one rod always let gas in even w/ secondaries closed. Carefully bent hanger back to correct shape, put rods back in, & problem solved. A little curb idle adjustment & dwell improved to 27 degrees, good enough for Valentine's Day.
Old Feb 17, 2009 | 04:47 AM
jamon8's Avatar
Engine: 350 tpi
sweet
keep her alive and pumpin
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
