Where to put HEI Bat Wire
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
im going to carb now where should i run my battery wire off the tach to and how can i hook up and electric choke carb?
Transmission: 4L80E/4L80E
The BATT terminal is switched ignition power, the pink wire that went to the coil originally.
The white wire that went to the original coil goes to the TACH terminal.
The electric choke gets switched 12 volts. Do not use the same wire that goes to the distributor.
Car: 87 iroc-z28
Transmission: th350
Re: Where to put HEI Bat Wire
the battery wire off the tach goes to the dizzy next to the power wire. should be labeled TACH right above where it attaches.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
