Holley 700 double pumper
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I was wondering if a 700 double pumper is enough for a moderate modded 383? The cam's duration @ .050" 240*/246*; here is the dyno sheet for the cam: http://www.compcams.com/Technical/Dy...84H-10_001.asp the dyno sheet was setup with a 750. I bought this carb under the impression it was a 750...its my own fault for not getting the numbers and double checking...
Transmission: 4L80E/4L80E
It'll run. You'll lose a little on the top end with a dual plane intake. A 750 would be better.
RedLeader289
May 28, 2019 01:47 PM
skinny z
Oct 5, 2015 06:23 PM
Royal_Z
Sep 30, 2015 08:45 PM
