Cant idle down new holley
Old Mar 29, 2009 | 03:50 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I bought a new holley 650 street hp double pumper. I preset and cleaned everything before I bolted it on, set the accelerator pump clearance, and set the secondary screw 1/2 turn past touching as per holley's instructions. I can't get it to idle low enough, I can turn the idle screw all the way out and it is still too high. Idle mixture is set, and I am running 12* initial timing, and have the vacuum advance set to full manifold and am also running a pvc breather. I pull about 17" of vacuum at idle around 1100. I have an LT4 hot cam.
Old Mar 29, 2009 | 09:48 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Re: Cant idle down new holley
nevermind i figured it out, had to close the secondaries some more
Old Mar 30, 2009 | 12:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Glad you figured it out. Most people don't realize both primaries and secondaries are involved in idle speed.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
