fuel pump suggestions
Old Apr 7, 2009 | 03:20 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
alright, so i just ditched the crossfire setup in my car. now running a holley 4bbl 4150 with a GM intake.
question is, is there a regulator made that will bring the fuel pressure down from my intank electric fuel pump enough to not spill gas out of my carb? or do i need to go ahead and install the mechanical pump.
thanks
Old Apr 7, 2009 | 08:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You couldn't have searched, because this is discussed regularly.
Yes, Mallory 4309, and others. You need one that uses a return to control pressure, because the factory in-tank electric pump needs a constant flow of fuel to keep cool. The cheap dead-head type of regulator will burn it out.
Old Apr 8, 2009 | 01:12 AM
Re: fuel pump suggestions
thanks man. ill get one of those ordered as soon as i can! this will save so much time and painful effort! haha
do you have a suggestion of where to put it? as far as on the car
Old Apr 8, 2009 | 07:40 AM
five7kid's Avatar
Wherever is convenient in the engine compartment. Away from heat sources is always a good idea.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
