throttle cable and tvs linkage.
Old Apr 25, 2009 | 08:29 AM
one92rs's Avatar
Car: SOLD!!!!!
man unless you want to spend a good amount of money or trial and error this can be a pain. went with the holley bracket that put everything way to close. tried different ideas here and there. then i found a mrgasket bracket at the auto parts that seemed to work fine. except that it was very flimsy and chaneged everything. i bought a piece of 1/8 X 3" flat aluminum stock from the hardware store. bent it around and then attached the bracket to it with screws. made it where the bracket bolted to to the intake and the back of the carb. adjusted it all out and it works perfect. have about 40.00 invested in it.
Old Apr 26, 2009 | 10:43 AM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
Re: throttle cable and tvs linkage.
NICE JOB MAN... I think this was one of the hardest things to get right after my swap to carb....someone should make a bracket that works without fabrication cause even with the "correct" Holley bracket I had to move it with a fabbed piece of steel.
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
Magman
Sep 14, 2015 01:30 AM
TheTraut88
Sep 11, 2015 05:16 AM
