Low Fuel Pressure
Old May 3, 2009 | 09:26 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Low Fuel Pressure
I run a holley blue with a holley regulator.
It seems that the regulator sticks. The fuel pressure will jump from 3.5 to 6 lbs and the regulator makes a solonoid like sound.
I removed and cleaned the filter which is in line before pump. I was stopped up with fuel cell foam. After cleaning problem did not go away.
All hose is 8 an.
Could I have a pump or regulator problem.
Fuel gauge is a VOD with a mallory isolator connected to the regulator. Run this set up for 3 years. No problems until this weekend.
Old May 4, 2009 | 09:56 PM
SDIF's Avatar
Re: Low Fuel Pressure
ttt
Old May 4, 2009 | 10:04 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I'd check the pressure before the regulator and see if it's got consistent pressure and move on from there...
Old May 5, 2009 | 01:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
After cleaning what, the filter or the regulator?
Old May 5, 2009 | 08:41 PM
SDIF's Avatar
The filter.
tank to filter to pump to regulator to carb.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
