misses when first started
Old May 5, 2009 | 11:32 AM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
I have a 86 iroc 355 w/ carb, edelbrock rpm performer intake, fuelie heads, comp cams extreme enegy cam. when i start the car for the first time of the day, it is running on only 6 or 7 cylinders. it will do this all day, the only way i can get it to clear up is to floor it for about 6-8 seconds. it will run perfect the rest of the day. im thinking the plugs get something on them causing them not to fire until i floor it. if i change them, the car doesnt miss when i start it until a few days later. i first thought the carb, but i swapped carbs, still does it. have good fuel pressure. any suggestion are greatly appreciated.
eightsixseven
Dec 16, 2024 01:50 PM
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
