Help me identify my carb
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
So I have two carbs that came with my car when I bought it off the previous owner. One looks like every other qjet Ive seen but the other has an extra port on it and Im not sure what its for. I've attached some pictures. My car has a wire that fits this port and the car seems to run better when I use this carb with that wire hooked up. I'm currently using a qjet that doesnt have this plug on it and while it does run, it idles rougher and doesnt seem to pull as hard. I removed this carb off my car because I suspect it is leaking and needs a rebuild (the car smelled of gas for hours after being driven with this carb on). What's the plug for?
Engine: Carb'd 305
Re: Help me identify my carb
Thats what I thought it was. I assume you can still rebuild a cc-qjet? Im surprised it is a cc qjet because supposedly cc cars never made it to canada.
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
2012sergen11
Oct 13, 2015 07:38 PM
Damon
Sep 26, 2015 04:29 PM
Linson
Sep 21, 2015 01:08 PM
