Idle Bleed on 3310....
Old May 20, 2009 | 09:11 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
>Many tuner books recommend drilling out slightly, the idle bleeds on the Holley 3310 to lean out the idle....idle being too rich with this carb on a 350. Has anybody done this? Does it work? Obviously I want to know before I mess up my carb! I've dropped my primary jets to 70's and have my mixture screws out 1/2 turn only.....and it still smells rich. FP is 6psi and my cam is a ZZ4. Everything else runs great! When the sec. kicks in, the car just takes off with no bogs!
Old May 20, 2009 | 02:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't drilled out fixed orfi, but I have messed with replaceable bleeds. It doesn't take much, and making them bigger is a lot easier than making them smaller. You need precision drill bits, which last time I checked were about $100 for a set that would cover both idle and high speed sizes.
Old May 20, 2009 | 03:53 PM
wdigitog's Avatar
Re: Idle Bleed on 3310....
>So, using the interchangeable bleeds: do you need large changes to lean out the idle mixture?
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
dimented24x7
Sep 6, 2015 03:51 PM
