2.8 mpi to v8 swap
Old May 21, 2009 | 05:14 PM
tom h's Avatar
Car: 1988 camaro z-28
Engine: built 350
Axle/Gears: 323 one wheel wonder
2.8 mpi to v8 swap
any help would be appreciated switching out mpi unit for built 350 and 700r4 trans i redid trans for setup i need but cant seem to figure wires for starter alternator coming out of firewall i am using mallory unilite setup and holley stand alone fuel pump and was hoping not to use toggle switches this car came to me in boxes and i am slowing restoring this car so any help with wireing what i can use and what i can get rid of to have a clean engine bay would be appreciated thanks
Old May 21, 2009 | 06:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
What year is your car? There are a few bulkhead connector pin-outs here http://www.team3rdgen.com/modules/3rdGenLS1/Wiring.htm that will get you started.
Plan on dropping the tank to remove the stock in-tank electric fuel pump.
Old May 23, 2009 | 10:45 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: 2.8 mpi to v8 swap
The wiring harness that you need comes out of the firewall next to the power brake booster. The other harness went over the AC box and will not be needed.
Old May 23, 2009 | 11:33 AM
tom h's Avatar
Engine: built 350
thanks for all your help my camaro should be running next week saw your post i live in omaha
Zane Story
Oct 8, 2015 12:40 PM
usafirebird
Sep 29, 2015 11:58 PM
89bird2.8
Sep 22, 2015 05:28 PM
89bird2.8
Sep 18, 2015 07:46 PM
