91 rs 5.0 ecm
Car: check
Engine: check
Transmission: check
Re: 91 rs 5.0 ecm
As long as the TBI harness was also swapped in it should work. An '89 Firebird should also have VATs, as the '91 ECM will require it.
RBob.
RBob.
Re: 91 rs 5.0 ecm
Thanks. I did swap the tbi harnesse. Yes the 89 does have vats so did the 91 I got the ecm from. The harness is from a 88 camaro tbi without vats. Shouldn't matter tho should it?
Car: check
Engine: check
Transmission: check
Re: 91 rs 5.0 ecm
efiguy
Sep 27, 2015 01:30 PM
