my car is a 92 trans am i am swaping the tpi over to carb. my reglator is a barry grant 171021 i am using the factory in tank fuel pump. the problem i am having is converting the factory fuel lines (inlet and bypass) to the regulator i am going to use rubber hose from the regulator to the carb. i cannot find any kinds of adaptors to adapt the fuel lines to the 3/8 npt regulator. this is all i lack to get my car running..
https://www.thirdgen.org/forums/carb...bi-update.html
this is my swap write up. i got my fittings from summit racing. look down in the post. i listed the measurements for the fittings.
thanks for the help. i found those fittins on ebay about 30 mins after i posted..i should have them by wednesday. hopefully my car will be running in a couple of weeks. (monetary situation is a little bleak)
how did you mount your regulator? i cant find a mout kit for it. i can make a custom mount but i dont want to if i dont have to lol
Quote:
i used a piece of 1/8X3 aluminum stock from lowes. bent it and drilled a hole for the return line on the bottom. this is the best pic i have of it.Originally Posted by 92whiteta
