mounting holley blue pump
Old May 29, 2009 | 10:02 AM
fullcircle's Avatar
Car: 91 RS
Engine: 355, vortec heads, carb
Transmission: 700
Axle/Gears: 3.42 posi
Want to install a holley blue pump. Thought about putting it where the factory fuel filter is, and putting a filter in my carb. Any better ideas?
Old May 31, 2009 | 10:46 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Re: mounting holley blue pump
I mounted mine right where the rubber line is between the steel lines before the tank. I would advise mounting a screen before the tank and the pump. Tip: mount the holley blue to the car using lots of rubber as a insulator... the pump makes some noise and reports say it is the vibrating part (something like that)
Old Jun 1, 2009 | 12:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Let's establish a base line here.
Why do you want to install a Holley Blue?
Are you removing the in-tank electric pump? If you weren't planning on it, start planning on it now.
Since you have to drop the tank to remove the in-tank electric pump, why not just put in a better in-tank electric pump?
If you really want to go with the Holley Blue, you need to drop the tank and remove the in-tank electric pump. There is a sticky in the top section of this forum that shows how to convert the pick-up/sending unit to "mechanical", including a pick-up sock. With that sock, you don't need a filter before the pump. Put the pump before the stock filter some place, and use the stock in-line filter. You should still have the inlet filter in the carb.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
z28_AJ
Aug 27, 2015 08:59 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
