replacing carb on 86 trans am
Old Jun 10, 2009 | 10:54 AM
hbk3001's Avatar
I Have an 86 trans am with a 305 and one of those computer controlled carbs, I was thinking about swapping it with a holley 650 dbl pump that is vaccum controled with elec choke instead of the computer one which is given me nothing but trouble. Will this work?
Old Jun 10, 2009 | 11:13 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: replacing carb on 86 trans am
Welcome to TGO.
It's not as easy as just swapping the carb. The computer also controls the ignition and torque converter lockup so the dist will have to be swapped for a mechanical one and an alternate means of locking the converter will have to be installed.
Swapping to a different carb will not gain you any performance over a properly functioning q-jet unless your engine is pretty wild. You can rebuild the q-jet yourself, send it off or purchase a rebuilt one.
It may not even be the carb. What particular problems are you having?
Old Jun 10, 2009 | 12:24 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
yeah what he said.
Also if you do swap out. You dont need anything bigger than a 4160 series 600cfm Holley. 650 is too big for that motor.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
