q-Jet idle adjustment
Re: q-Jet idle adjustment
there's a screw on the driver's side holding the primary valves partially open. In the best case scenario this should not be used at all, but the carb's idle system should provide the needed rpm's. Is your qjet feedback or non feedback?
look at the lever that controls the throttle. when the gas pedal is in "off" position this lever is supported by that screw. If not and it stops at something else than it's not your solution.
