Electric or Manual?
Old Jul 11, 2009 | 11:58 AM
MitchellDeMoor's Avatar
Car: 1991
Transmission: 700
Electric or Manual?
I am just ordering a new 600cfm carb on Jegs. They have three to chose from http://www.jegs.com/p/Edelbrock/Edel...43643/10002/-1 What should I chose? One has electric choke and one has manual? I just use this car as an everyday driver and will race it once in a while.
Old Jul 11, 2009 | 05:13 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Electric or Manual?
I prefer an electric choke personally, it does all the work for you (Nothing wrong with a manual choke though, but you might have to buy a choke cable if it's not included)
Old Jul 11, 2009 | 05:16 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
the most intellegent choice would be to get an electric choke. i drive with no choke everyday. the car is cranky in the mornings, especially when its cold outside, but not too bad once the car warms up. but most people will tell you to run an electric choke.
Old Jul 11, 2009 | 08:08 PM
ronterry's Avatar
Car: '94 Corvette
It really depends on how streetable your cam is. For a street/strip motor, a manual is a better choice, otherwise the electric works good once you tune it and know the quirks if you have a cam with some duration.
Something I always liked about the manual is you can control exactly where to bump up the throttle and choke plate. With electric your screwed once the choke coils heat up and you shut the motor off early.
Old Jul 13, 2009 | 11:26 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i prefer electric...it is easier tu run in the mornings.or better yet,,,you don't need to do anything but tap the gas pedal and it goes on...i'm lazy!
Pac J
May 17, 2020 10:44 AM
bjpotter
Oct 2, 2015 09:12 AM
tattmann
Sep 27, 2015 05:20 PM
lanceflame44
Sep 25, 2015 12:28 PM
Magman
Sep 12, 2015 11:55 PM
