CARB leak?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
CARB leak?
I seem to have a small wet spot on the strangest place. If you look directly at the carb and look at the built in fuel filter housing there is a small round indent from factory which seems to be wet , not dripping just wet. Any ideas? I can seem to pinpoint the leak just on that spot it seems odd because its part of the carb itself by the looks of it. I seem to be getting a slight stumbled from it.
Transmission: 4L80E/4L80E
That indent is a plug for the hole that is necessary to drill the passage inside the carb. Clean it well and put epoxy over it.
It doesn't have anything to do with the stumbling problem.
GeneralIesrussi
Sep 3, 2015 03:23 AM
