edelbrock 1406 no spring under accelerator nozzles
Old Sep 13, 2009 | 10:53 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I took my carb apart to clean it and change jets i took off the accelerator pump nozzles but i didnt see any spring just the ball and the small brass rod. in one of my rebuild books it says nothing about the spring and showed no pics of it in the expolde view. but in other books and expoldes it shows it and talks about it. so im a bit confused if it was spouse to be in my model of carb and i cant find any part numbers for it if may carb needs that spring then i would like to know where to order it. iv looked on edelbrock.com and tryed to call but i can never seem to get a hold of anyone. anyway hope someone could help me out thanks
Old Sep 14, 2009 | 09:27 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: edelbrock 1406 no spring under accelerator nozzles
did you check this sticky? https://www.thirdgen.org/forums/carb...-diagrams.html
i am not familiar with the edelbrocks, so i cant help dude. good luck
Old Sep 15, 2009 | 12:45 AM
FueledSoul's Avatar
yea some show that spring others dont. . . eh
Old Sep 15, 2009 | 01:21 PM
guess yours doesnt require it, is it causeing a problem?
amcnellis
Sep 16, 2015 04:16 PM
toronto formula
Sep 10, 2015 07:31 AM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
lakeffect2
Sep 7, 2015 03:52 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
