newb carb question.
Car: 89 iroc 98 T/A
Engine: LSX
newb carb question.
just got done with tpi to carb swap. car is backfiring through carb pretty badly, even shot up a few flames for me, cant get to run, i have the 4309 return style mallory regulator. seems like its flooding to me i checked distributor got on top dead center and all that good stuff, but no luck.
BUT BUT BUT when i turn the key on the fuel pump primes up, and while im trying to start it i can hear it kicking in. IS THIS THE REASON, do i need to wire up something to keep it from kicking in like it is? not a carb guy any help will be greatly appreciated.
Transmission: 4L80E/4L80E
You want the fuel pump to kick on in order to fill the carb bowl. Once they're full, the regulator will control pressure so the float needle & seat can shut off the flow to the fuel bowl.
Check your spark plug wire firing order. You may also not have the timing quite right yet.
