Quick Fuel Adjustable Vacuum Secondary Kit
Old Sep 23, 2009 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Installation and set-up ease? Other user comments?
JamesC
Old Sep 23, 2009 | 07:18 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Quick Fuel Adjustable Vacuum Secondary Kit
Its a nice setup. Just bolt up and go for a drive. You will have to do some adjusting for your own setup, but once you get it fine tuned, your good to go.
Just a turn of a screw without all the spring swaps.
Old Sep 23, 2009 | 07:32 AM
JamesC's Avatar
Any possible installation woes that I should be aware of (Holley with an electric choke)?
JamesC
Old Sep 23, 2009 | 07:36 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I wasnt running a choke when I had the 3310, so I cant comment on that. But the istall was just unbolt and hook up the linkage.
Im sure Quickfuel designed it to use with a choke, but you could always call and ask them.
Old Sep 23, 2009 | 08:40 AM
JamesC's Avatar
My e-mail to the company has not yet generated a response.
JamesC
Old Sep 23, 2009 | 10:12 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Try calling them at (270) 793-0900‎. They are located in Bowling Green KY.
Close to Holley which posssibly owns Quick Fuel.
Old Sep 23, 2009 | 12:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Holley doesn't own Quick Fuel Technologies. QFT and Proform have a close relationship, though.
Mine was the early model, which was a modified Holley housing rather than their nice billet piece now. I had an electric choke, it fit without problems.
I'd also suggest using the weakest spring available. The one that came with my adjustable housing was a medium spring. I had previously purchased a spring assortment, and found the weak spring worked very well with the adjustable housing.
Installation is no harder than changing the spring without a quick change lid.
Old Aug 23, 2013 | 08:31 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I know this thread is old but I thought I would bump it. I just bought one of these and will be putting it on this evening. I went ahead and bought a spring kit based on five7kid saying he liked using the weakest spring.
specialized
Jun 18, 2022 09:26 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
TreDeClaw
Aug 14, 2015 06:58 PM
