Acceleration issue
Old Sep 28, 2009 | 01:57 AM
Red1985TransAm's Avatar
Acceleration issue
I've got an '85 Trans Am with a 305 and a 4 barrel carb. I had a rebuilt carburetor installed and now when I start it up after it sits overnight it sputters and won't accelerate for about a block or two then it seems to straighten out and run good. I tried warming it up before driving it by giving it a little gas and I would get a lot of backfiring under the hood. It would run pretty good once the backfiring stopped. Appears to be running a little rich. Got black exhaust marks on the bumper. Took it in to a local well equipped garage to see if the timing was off and they told me everything is fine. No engine lights are coming on so I'm at a loss. MAF sensor? Oxgen sensor? Bad carb sensor? Ran carb cleaner with valve treatment throught it and that cut down on the backfiring.
Old Sep 28, 2009 | 06:13 AM
Damon's Avatar
Re: Acceleration issue
Sounds like the choke isn't adjusted properly- staying too far closed on initial startup. The vacuum canister on the pass. side of the carb determines how far the choke is pulled open immediately after first cold startup. Once the choke begins the warm up it opens on it's own and the problem goes away until the next cold startup.
Old Sep 29, 2009 | 10:36 AM
Yeah that sounds like the issue. That's probably the best answer I've recieved. Never fiddled with the choke. Is that something I want to attempt?
Old Sep 29, 2009 | 12:05 PM
fleetmgr's Avatar
Sure, they're pretty simple to adjust. What kind of carb?
Old Sep 29, 2009 | 12:27 PM
It's a Quadrajet E4ME.
Old Oct 2, 2009 | 01:23 AM
Figured out how to adjust the choke. Runs like a totally different car now. Like new. Unbelievable. Thanks!
Old Oct 2, 2009 | 09:40 PM
lymfircil's Avatar
Thank you for your information and soon reply to my question.
__________________
Electric adjustable beds prices reviews - Electric adjustable beds prices UK - Sleep Comfort adjustable bed mattress air
IROCtometal
Sep 20, 2015 11:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
