carburetor Under all engine operating conditions
Old Oct 2, 2009 | 01:00 AM
jackson11's Avatar
Under all engine operating conditions, the carburetor must:
Measure the airflow of the engine
Deliver the correct amount of fuel to keep the fuel/air mixture in the proper range (adjusting for factors such as temperature)
Mix the two finely and evenly
This job would be simple if air and gasoline (petrol) were ideal fluids; in practice, however, their deviations from ideal behavior due to viscosity, fluid drag, inertia, etc. require a great deal of complexity to compensate for exceptionally high or low engine speeds. A carburetor must provide the proper fuel/air mixture across a wide range of ambient temperatures, atmospheric pressures, engine speeds and loads, and centrifugal forces:
Cold start
Hot start
Idling or slow-running
Acceleration
High speed / high power at full throttle
Cruising at part throttle (light load)
In addition, modern carburetors are required to do this while maintaining low rates of exhaust emissions.
Old Oct 4, 2009 | 02:02 PM
Goosehead's Avatar
Re: carburetor Under all engine operating conditions
Soooooooooo, after this useful information we should check out your links....or so...?
weird guy you are...
Vintageracer
Jan 10, 2020 05:33 PM
masonta
Aug 31, 2015 10:14 PM
beachrodder
Aug 25, 2015 08:05 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
