Completed tpi to carb swap, and hid kit
Car: 86 IROC
Engine: 355
Transmission: WC 5spd
Axle/Gears: 3.24
Re: Completed tpi to carb swap, and hid kit
Looks crisp man! I'm doing the same swap....how long did it take you? Any tricks to pass along?
It took about 2 days. Make sure you have the right manifold. I got the wrong intake manifold and the bolts didnt fit. So I had to return and get the correct one. It has better pulling than the tpi setup. Make sure the timing is right. Mine is still a little off, it is a little hard to start the car in the morning. But it runs great. Good luck with the setup and have fun.
Terrell351
Jun 13, 2021 01:13 PM
