Carberator switch Quadrajunk to Edlebrock 1406
Old Jan 28, 2010 | 05:17 PM
MetallicaWolfe's Avatar
Car: 1986 Berlinetta Camaro
Engine: 350 SWAP
Axle/Gears: Stock
Ok Ive seen all these posts about ooo keep your quadrajet blah blah blah far superior computer controlled if tuned right. My *** =] Ive had mine rebuilt 2-3 times & its always been junk. I'm sick of it =p
So now that I bought a edlebrock 1406, I need to know what I need to do to basically go from cc to non cc without screwing anything up etc You get my point xD I heard you need to change distributer and what not, so how will this affect my 700r4, is there anything else I need to do?
Btw my car gets like 8mpg, actually I'm pretty sure just under that, partial transmission & the horrible quadrajet, & my cars basically all stock
Old Jan 28, 2010 | 05:20 PM
Project-RS's Avatar
Re: Carberator switch Quadrajunk to Edlebrock 1406
im doing the same thing but with a twist. check my pics in my profile, and if you like pm me and i can tell you what i did
Old Jan 28, 2010 | 05:24 PM
Engine: 350 SWAP
Axle/Gears: Stock
Haha ok, messaged you, so anyone else? xD
Old Jan 28, 2010 | 05:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Ugh, ok ok, i'll admit i'm a fan of the Q-jet - but the non-cc version. They are simpler. Computer controlled carbs scare me.
But if you're going to "upgrade" your quadrajet, at least make it an upgrade eh? There's a list of carbs that are BETTER than a q-jet (and i'm a q-jet fan, but i'll admit there is improvements out there) -- an Edelbrock is NOT a better carb. A holley, Demon, etc are going to be better. But this Edelbrock will just be more of a headache.
Here's what you need to do though:
- You will need a non computer controlled distributor. $100 off summit for a base model. I'd recommend you get a re-curving kit too
- You didn't have the foresight to mention which transmission you have. If you have a stickshift, no worries, if you have an automatic - then you need a way to control your lockup / kickdown. To be honest, I forget which it is, since I never had to deal with it...
I think that's the main two things. You can then remove your computer in your car and pretty much throw it away. Pull your check engine light, and throw away your O2 sensor, they're decorations now.
Old Jan 28, 2010 | 05:43 PM
Project-RS's Avatar
i gave him the part number for the lockup sonix. so thats solved. im doing the same non ecu setup but tunnel ram
Engine: 350 SWAP
Axle/Gears: Stock
Yes I did, I said a 700r4 which is automatic, duh lol
Old Jan 28, 2010 | 05:47 PM
Project-RS's Avatar
for your wire harness (ecu, passenger side wires in the fender area) all those can be pulled, but take your time and dont pull the wrong ones. i hope your writing this down.....lol
Old Jan 28, 2010 | 05:50 PM
Engine: 350 SWAP
Axle/Gears: Stock
Hahaha, I'm learning slowly
Old Jan 28, 2010 | 05:52 PM
Project-RS's Avatar
your in good hands here. distributor from summitracing part number SUM-850001R. 90.00 is a great deal. i had that one in my old 85 camaro. made for non ecu setups
Old Jan 28, 2010 | 05:56 PM
Engine: 350 SWAP
Axle/Gears: Stock
Wrong, anything is better than my quadrajunk =]
Old Jan 28, 2010 | 06:00 PM
Project-RS's Avatar
any other info you need?
Old Jan 28, 2010 | 06:19 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
No, Edlebrock carbs really aren't. Trust me I've got one and it sucks.
Old Jan 28, 2010 | 08:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And the Zen master said, "We'll see."
Old Jan 28, 2010 | 09:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i just threw one (edelcrock) in the garbage if that makes you feel differently, was a 750 but same crap
Old Jan 29, 2010 | 03:37 PM
87WS6's Avatar
That's where mine will be headed as soon as I can. Too many projects going on and it isn't as if that car is a daily driver or anything. The thing isn't that old and the throttle blades stick on it.
Old Jan 29, 2010 | 07:16 PM
not one's Avatar
Car: 1984 camaro
Engine: weezing 305
Transmission: th350
Axle/Gears: 7.5 3.23 mini spooled
thinking about tossing mine and using a holley. can't get the damn thing dialed in.
Old Jan 29, 2010 | 07:54 PM
camaro350z28's Avatar
ive got a distributor i will sell you... used on my 85 when i had switched to a demon carb
Old Jan 29, 2010 | 08:01 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Well, what have or haven't you tried changing. What is your "method" of tuning, wideband,02,1/4mi track, or the good old butt dyno.
There is no reason outside of mechanical failure where one carb(edelbrock) is harder to tune(within reason) than another.
Is your ignition in good order, how about fuel supply(mechanical,electric, gravity fed-j/k).
I'm sick of hearing excuses because Brand A is junk but Brand B will cure cancer.
I like holley myself, it's what I use, what I know very well. When I was DD'ing my camaro I got 21/13 mpg infront of a th-350/3.23's and I wasn't nice to it. I don't even have a choke but I have no problems firing it up first try on a cool michigan mornings.
Enough Q-jet and Edelbrock is crap just because you don't know how to tune them, I have SEEN edelbrock inducted vehicles(454 4x4 chevy 2500) TEAR stuff up.
To the OP, I don't care how many times something is rebuilt, if it is not rebuilt correctly it is going to come out crappy. Have somebody that KNOWS qjets rebuild it and then let THEM tune it, I guarantee you will be satisfied.
EDIT: If you have the patience not only let them tune it, let them TEACH YOU how to tune it, as Al Einstein said, there is NO knowledge that is not power!
Old Jan 29, 2010 | 08:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Even when you rebuilt it correctly, it's not going to make a difference if it's not actually the problem.
Old Jan 29, 2010 | 08:13 PM
Project-RS's Avatar
i have 2 holley 600's. i might go to edelbrock ones. i had nothing wrong with my old edelbrock carb on my 85 years ago
Old Jan 29, 2010 | 08:26 PM
stroker_SS's Avatar
Engine: 355
SO true!
Old Jan 30, 2010 | 09:42 PM
not one's Avatar
Car: 1984 camaro
Engine: weezing 305
Transmission: th350
i agree with what you said, and i'm not saying that edelbrock is junk. all i was saying is that its not working for my combo and as i already have a holley i'd see if that worked any better.
Old Mar 24, 2010 | 09:30 PM
quad454's Avatar
Passenger side harness contains blue and green backup wires to transmission with 5 speed tranny!
Old Mar 26, 2010 | 01:42 AM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
looking to do the same what is the part number for the tranny fix? and will this work Vhttp://www.summitracing.com/parts.aspx?sku=MSD-8362&rtype=1?
Old Jun 5, 2010 | 01:16 PM
oguin_studking's Avatar
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
What was that part #? And CHRISBLAZZER I got that dist. im hopeing it'll work 4 me.
Old Jun 5, 2010 | 09:44 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
I will gladly take you cc quads from you if your going to throw them away
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
