Do i need Breathers?Why or why not
Old Feb 2, 2010 | 03:08 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello
do i need breathers? so yes why or why not?
the engine is a 350 1988 SB
it was before a tpi engine now its a carburated engine.
i have dress up my engine a little and don`t want to make a hole i the new valve covers for the breathers.
whats happen if i don`t use a breather?
thanks dennis
Old Feb 2, 2010 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You collect moisture in the crankcase. When mixed with certain combustion by-products, you get acids. Acids are not good in a crankcase.
Old Feb 2, 2010 | 07:19 PM
Damon's Avatar
Re: Do i need Breathers?Why or why not
You have to have some sort of venting of the crankcase or pressure will build up and blow out seals. Usually the valve cover gaskets and/or the shaft seal on the distributor.
Old Feb 2, 2010 | 07:34 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
I suggest a good PCV setup, breather in one cover pcv valve to the carb in the other. This will prevent your oil from turning into sludge in the crankcase. I would rather have a clean engine inside than out.
Old Feb 2, 2010 | 08:02 PM
ls six's Avatar
If you are clever you can hide the breather setup pretty well.
You can put the hole on the back of the cover near the firewall and run it to the carb or a remote breather/ oil sepperator.
Depending on the manifold design the vent/breather can vent from the lifter valley too. Older SBC's were vented like this. A tall single plane is ideal for this but even an airgap can be modded.
Old Feb 12, 2010 | 09:24 PM
BadHabit's Avatar
Car: 1989 TPI Formula, 1984 MCSS
Any reason you couldn't run the PCV valve to the vacuum fitting in the manifold behind the carb?
Old Feb 12, 2010 | 09:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll lean out the cylinder on that runner.
Old Feb 12, 2010 | 09:36 PM
Damon's Avatar
PCV valve is best run to the big port on the carb designed for it. Typically this port vents in the middle of the carb flange, helping to distribute it more evenly between the cylinders.
I've tried it on the intake manifold vacuum fitting and...... it worked exactly the same. Go figure. Old Pontiac engines have a similar setup, FYI. Can't be that horrible, right?
Old Feb 12, 2010 | 10:29 PM
BadHabit's Avatar
Well, the vac port is perched right on top of the #8 runner. That makes sense.
In the quest for a cleaner look, especially on the front half of the engine, I'm gonna look some more.
I'm still running a Q-Jet and may look at the port on the base of the carb where the power brake vac tube goes.
I can move the PB vac hose to the #8 runner vac port.
Thoughts on that?
Old Feb 12, 2010 | 11:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The PB line is fine in the manifold port.
Old Feb 25, 2010 | 03:36 PM
Car: camaro iroc-z
okey thanks
but there is a new problem now!
i need 2 big vacuum ports now one for the powerbrake booster and one for the pcv valve.
there is only 1 big vacuum port on the holley carb.
i want to use the vacuum port on the manifold but the carb is to close on the port!
there is 1 cm space left between the underside of the carb and the top of the vacuum port!
what to do now??
Old Feb 25, 2010 | 04:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use a thicker gasket, and see if you can fit a right-angled fitting into the manifold port.
Old Feb 25, 2010 | 06:56 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Wouldnt you tend to suck up or blow out a good bit of oil since there are no baffels back there to stop this from happening?? Ever run the breathers on the right side of a round track engine???hehehehe. Or simply put the valve cover on upside down? (And yes you CAN do that with valve covers made for round track)
Old Feb 25, 2010 | 10:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Using a tall cover will give you enough room to use some sort of baffle.
Old Feb 26, 2010 | 04:04 PM
Yeah, but thats only if you know how. And some people shouldnt be allowed to own tools much less take on making and installing/welding on a baffel!!LOL
Old Feb 27, 2010 | 12:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No need to weld, use a baffled grommet.
Pac J
May 17, 2020 10:44 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
sleprock
Sep 24, 2015 04:33 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
