q-jet carb bolts
Old Feb 18, 2010 | 07:23 AM
mjk1210's Avatar
Car: '83 TA
Engine: GM Performance 350
Axle/Gears: the slowest off the line
q-jet carb bolts
Hi guys. I picked up a 83 TA last summer and did all kinds of maintenance on it to get it back to running well. One thing I noticed was that the bolts going down through the carb into the manifold were constantly loosening back up. I'd snug them up good and a couple weeks later they would be kind of loose again. Not ideal for mixture I would assume. It's been sitting most of the winter and as the temp warms and snow melts I'll be getting her out on the street again sooooo...
My question is...what is the best recommendation for getting them to stay tight? I'm thinking blue loctite (non-permanent) would be the best solution but I wanted to double check.
Actually I'm having the same problem with valve cover bolts so your best recommendation for those as well.
Thanks!
Old Feb 18, 2010 | 10:17 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Re: q-jet carb bolts
That's the spirit!
Old Feb 19, 2010 | 12:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you have washers under the bolts?
Old Feb 19, 2010 | 12:29 PM
mjk1210's Avatar
Car: '83 TA
At the moment, I don't recall. Should there be? Or not? Certain thickness for certain length bolt? give me all the details.
Old Feb 19, 2010 | 01:26 PM
five7kid's Avatar
You need a flat washer to protect the air horn from distortion and galling. A lock washer between the flat washer and bolt head tends to help keep the bolts tight.
Old Feb 19, 2010 | 01:40 PM
mjk1210's Avatar
Car: '83 TA
Cool. Thx. Any min/max on the washer size for optimum prevention of warping?
An additional question: the rubber that the air cleaner cover is seated on is mostly rotten away. What is the name for the seal at that spot? Easy to get?
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
