Engine runs smoother with high dwell
Old Feb 21, 2010 | 05:41 AM
DoubleV's Avatar
I run the CCC system on a mild Olds 350. I hadn't much time for serious tuning, but I've been playing with it here and there.
I've been trying to smooth out the rough idle. No matter what I seem to do, the idle is rough when I'm at or near the correct dwell so I decided to tune for best idle regardless of dwell to see what happens. Result? Smooth idle = VERY high dwell reading ( 94.7% ), and the dwell goes down ( to about 68% ) when I give it a quick rev, then goes back to 94.7%.
High dwell indicated ECM is responding to an overly rich condition. OK, so back off on the IAB right? If I do, it idles rough again. Hmmm.
Unplugging the MC solenoid ( full rich ) provides smooth idle. Obviously, my engine appears to like 'rich'.
Tried adjusting mixture screws but haven't tried anything lower than about 3 1/2+ turns out. I figure that turning the IAB out accomplishes the same as turning mixture screws in though. Will try 3 turns out next.
Adjusting rich stop ( and to a lesser extent lean stop ) effect idle quality too. As I said though, I adjusted for smooth idle and not good dwell. I don't know if my current setting achieve the 3mm plunger travel.
It just seems like when I try to adjust things by the book, it doesn't work. I want smooth idle AND proper dwell darn it!
The carbs rebuilt and I understand what all the adjustments do and generally how the system works. Only carb mod is 75 jets were replaced by 76 jets.
Old Feb 22, 2010 | 03:00 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Engine runs smoother with high dwell
Many be that one of the cyinders is running at a different Air fuel ratio than the others.
Vacuum leak?
Old Feb 22, 2010 | 03:06 AM
DoubleV's Avatar
Engine is newly rebuilt ( professionally ), so I don't think there's an issue there. I checked about 100 times for vaccum leaks and everything is good with that too.
Engine pulls about 20" of vaccum at idle too.
Old Feb 22, 2010 | 03:41 AM
F-BIRD'88's Avatar
Read the voltage of the 02 sensor with a VO A meter as you tune. A heat gun will show exhaust manifold port temps variations. Indicating cylinders that are running different than all the others, or miss fireing.
you are assuming a lot. Everything mentioned leads to 1 or more cylinders wanting for more fuel.
A intake manifold vacuum leak is highly suspect. Reguardless of how much you paid for the rebuild.
Old Feb 22, 2010 | 05:17 AM
DoubleV's Avatar
I have a scanner that reads volts and crosscounts, but I don't know what's considered to be good numbers or not. What are good crosscount numbers and voltage readings?
O2 sensor is a brand new GM AC Delco unit.
What do you think would be the most likey reason(s) for having 1 or more cylinders wanting more fuel than the others on a fresh engine with proper break-in? I haven't checked the plugs since last year, but when I did, they all seemed equally normal. A tad on the lean side perhaps.
Intake manifold leak was the first thing I checked for. Sprayed starting fluid all around ends and carb base. Nothing. Retorqued intake bolts ( they were all good ). Even asked the builder if he might have made a mistake sealing the intake and he said 'no way'. Of course that doesn't mean it's true...
Wouldn't any major vaccum leaks/sealing problems show up on a vaccum gauge?
Old Feb 24, 2010 | 06:31 AM
DoubleV's Avatar
Anyone?
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
