Fuel Pressure
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel Pressure
5-7 depending on the carb.
And you HAVE to use a return-style regulator - there's no other way - if it doesn't state return style, it isn't (and if it cost less than $80 new, it isn't).
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Fuel Pressure
why can't you use a dead head regulator? mine works good
Transmission: 4L80E/4L80E
Because the in-tank electric fuel pump needs constant flow through it to keep it cool. A dead-head reg will kill the pump eventually.
Re: Fuel Pressure
i didn't see "in tank" in his post sorry
Car: 1989 Camaro RS
Engine: LO5 350
Re: Fuel Pressure
if you get one from quick fuel technology part number 30-899, they are $66.37, i just got mine the other day from summit
Re: Fuel Pressure
I could be mistaken.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
