choke install? help please
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I got my car with an edelbrock car with a manual choke. the guy said he removed it because it isnt that hard to start anyway. The plate is still there and so is the little bracket on the side of the carb that controls the choke. How do i reinstall the choke? Do i just run a line inside the car or what? thanks guys
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: choke install? help please
If all that is still there, then he probably didn't remove the choke, he just never hooked it up to a cable.
You can either run a choke cable to the interior (yuck), or you can convert to an electric choke.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
http://www.edelbrock.com/automotive_.../1000/1402.pdf
Page 4 has some info - might be more detailed info for your specific carb at
http://www.edelbrock.com/automotive_...ll/index.shtml
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 11, 2015 03:17 PM
