fuel pressure regulator problems
Old Mar 14, 2010 | 09:30 PM
adams86z's Avatar
Car: 1986 z-28 hardtop
Engine: 355ci w/nos cheater
Transmission: th-350 3300 stall
Axle/Gears: 7.75in 3.70s
I am having problems with my fuel pressure was woundering if anybody has ran into this problem and could help me out. I recently dropped a 350 carbed engine in my 86 and i am running a holley blue pump part# h6194, cant get fuel pressure under 12psi , tryed 2 different regulators 3 port 3/8npt in and out, the numbers on them make me believe they are for blue pump, 1 i bought new was for a blue pump also. I have not deadheaded fuel pressure before regulator so i can tell you what that pressure is yet. if it matters i am running -8an lines with 1/2 aluminum lines. thanks in advance for any help, i need to get this thing on the road soon. Can a fuel pump problem cause this????
Old Mar 14, 2010 | 09:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel pressure regulator problems
Which regulators have you tried?
Old Mar 14, 2010 | 09:39 PM
adams86z's Avatar
first one was procomp junk, only thing chinese in my car other than probably radio, anyways it was advertized to be comparble to a blue pump regulator, after that tryed on my buddy had, looked the same anyways, identical other than saying holley on it, i dont have the part number but i can look if that helps. one i have in there now is a holley 34r 66579 only number i see on it cant find any info on that number but i hope r stands for red, the other thing i might try tomarrow is adjusting it when running, was checking with engine off.
Old Mar 15, 2010 | 06:31 PM
adams86z's Avatar
yea that helped dident relize car had to be running to set pressure, i was just turning pump on trying to set pressure
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
