[[Quick Question: Carb and Intake Holes]]
Transmission: 4L80E/4L80E
The one on the carb is used for the power brake booster.
The one on the intake manifold is used for the transmission vacuum modulator, and the HVAC reservoir (not sure if yours is the smaller one that goes under the cowl lip, or the larger ball that mounts in the fenderwell under the vapor canister.
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Re: [[Quick Question: Carb and Intake Holes]]
But back to topic, what actually goes into the intake hole? A plug with two little vaccuum nipples on it? and what does one of these HVAC reservoirs look like? ill do some looking tonight and see what I can come up with.
And the carb fitting is strictly the brake booster?
The manifold fitting has male threads to screw into the manifold, and hose nipples coming out of it to hook up rubber (or plastic) vacuum lines. You can make one from hardware store brass fittings.
The carb port was only used for the vacuum booster on factory carb'd cars.
Car: 82 Firebird
Engine: Boosted LSX
Alright, thanks alot once again.
