Throttle cable doesnt have enough throw.
Old Mar 22, 2010 | 10:39 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
So when i was adjusting my TV cable i noticed that my carb wasn't opening all the way when i floored my car. It seems like the pedal doesn't have enough throw to open the secondaries all the way. I'm running a holley 700 DP with the throttle/kickdown bracket.
Any ideas?
Thanks, Chas
Old Mar 22, 2010 | 12:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You said "throttle/kick down bracket" (technically, it isn't a "kick down").
Did you use the geometry corrector bracket that bolts to the carb throttle arm itself?
Old Mar 22, 2010 | 01:20 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: Throttle cable doesnt have enough throw.
For the throttle or the TV cable?
This is the bracket i had to buy: http://www.summitracing.com/parts/HLY-20-95/
Is this the corrector your talking about?: http://www.summitracing.com/parts/SUM-700202/
I dont have enough throw for my throttle/gas pedal not the throttle valve.
I might be missing something here....
Old Mar 22, 2010 | 01:45 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
You'll have to fab up a piece to move the bracket back. I bought an aftermarket TV cable bracket and throttle cable bracket. I had to use some plate steel and move the bracket so it would have enough pull.
Old Mar 22, 2010 | 02:06 PM
five7kid's Avatar
Yes. Without it, your TH700 will not be happy.
Understood, just pointing out another problem that is often overlooked.
Old Mar 22, 2010 | 03:46 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
ahh ok so is there a fix for the throttle cable? right now the bracket is as far back as it can go without opening the primaries permaturely. When i floor it the secondarys dont open all the way. The pedal does not have anything behind it except floor pan.
Its not the carb because i can open the secondarys at WOT by moving the throttle plate.
Old Mar 22, 2010 | 03:54 PM
five7kid's Avatar
Where are you mounting the throttle cable on the throttle arm?
Old Mar 22, 2010 | 04:38 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
The marker is pointing to the spot. This is not the carb on my car but another that i have. I'm up at school so I can't take a pic of the carb on the car.
The TV cable is connected to the furthest bottom hole.
Old Mar 22, 2010 | 10:04 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
I was reading one of my holley rebuild books and it says to bend the connecting rod that engages the secondaries slightly to be sure they open all the way. How much should i bend it?
Old Mar 22, 2010 | 10:42 PM
five7kid's Avatar
Enough so that the primaries and secondaries are open fully, when you are opening the throttle arm by hand. You don't do that to make up for insufficient cable travel.
Speaking of the cable, you might want to check for a collapsed housing or failing cable wire.
Old Mar 22, 2010 | 11:20 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
They already open fully by hand. Where is the housing under the dash at the top of the pedal?
Old Mar 22, 2010 | 11:51 PM
five7kid's Avatar
If they both open completely by hand, then don't touch that secondary link.
The throttle cable housing is all visible in the engine compartment. The cable is hooked to the pedal above the pivot point - you have to remove the panel under the steering column to see it (assuming your panel is installed).
Old Mar 23, 2010 | 09:17 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Ok thanks
Old Mar 28, 2010 | 08:18 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Fixed my throw problem...there wasn't any adjustments that I could make to the pedal or the cable. I just grabbed the bottom of the pedal and bent it up a bit no prob now.
Old Mar 29, 2010 | 07:24 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
You could have just cut a piece of steel like I did and move the bracket back.
Old Mar 30, 2010 | 09:58 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
I still am going to but I need to get the car running and up to school and ill cut the throttle side off and weld it back further.
Old Mar 30, 2010 | 10:04 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
thats was i was gonna suggest, the pedal lever being bent. i have a cool story about that. i let a buddy drive my drag car and he stomped the pedal so hard he bent the bracket.
Old Mar 30, 2010 | 10:28 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
haha i might have done the same thing when i was racing a couple cars last summer....
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
