I think I might buy this...
I was wanting to upgrade my "84 ,auto ,305 ,"maro and i found this on summit.
http://www.summitracing.com/parts/CMB-03-0158/?rtype=10
anyone bought this kit and if so what are your thoughts about it.
also pics installed would be a plus.
P.S. please don't start with the "drop that dog 305 for a 350. I just want a little more power from the stock motor without a lot of down time.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: I think I might buy this...
I know you told me not to, but I just must - not to "dog", but as an FYI..
I got a used 350, carb to pan complete - plug and play, for $600 locally on Craigslist. Spent $120 on an HEI distributor, another $80 on a fuel pressure regulator (I was going from TBI to carb) - so for the same $800 I had a 350.
$850 seems high to me for that, but I guess is does have a Holley which are much more expensive than an Edelbrock (and I know, someone's going to say Edelebrock sucks and Holley is well worth the extra).
But - FYI...
Edelbrock 1406 600cfm carb new at Pep Boys about $250
Edelbrock Performer RPM intake $150
That's $400. Cams I'm no expert on prices or good choices, and the rest in that kit is fluff - gaskets ($40), air cleaner ($30), carb studs ($5) - so that's $475 excluding a cam buying the parts yourself (IF you are not oppose to an Edelbrock, which is a fine carb for a simple street app) - that leaves over $350 for a cam choice - never seen a cam go for $350 ... so I think you'd save yourself a couple hundred by putting your own "kit" together.
Just my
Good Luck with whatever you choose!
But - FYI...
Just my
Good Luck with whatever you choose! Supreme Member
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i have that carb for sale https://www.thirdgen.org/forums/engi...er-570cfm.html
Car: 1984 Camaro berlinetta
Engine: LG4 305
Transmission: 700-R4
Axle/Gears: 3.08 open diff
you also do not have to buy new eather. check ebay and craigs list for deals
i built the engine in my old '74 chevy k10 for cheap
vortec heads $40
summit stage 2 intake $100 (had to drill the center holes but ehh)
never used RV cam $60
thermo quad carb $30 (it was really cheap and works simialer to a Q-jet vary nice street carb)
low milage GM good wrench engine came out of a suburban $200
headers $40
total $470 (not including mic gaskets and what not)
thing was not fastest but it had enough power to move the 33" tires down the road no problem had a 700-R4 auto and 4.10 gears
vortec heads $40
headers $40
Car: 1983 Camaro Z28
Like I said i wanted thoughts on this kit. But I actually found a similar kit with a milder cam(maybe) for $550.
ALthough dropping in a 350 is an option. I know basicly nothing about V8 chevy's.. (mosly 240sx's with RBswaps) i have no idea where to start a 350 swap.
Engine: LG4 305
350 swap is simple
the 305 and 350 are the same externaly and interchange. it's just like if you where to pull the 305 for another 305
RedLeader289
May 28, 2019 01:47 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
