Edelbrock vacuum fitting
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Title says it all, I want to use the rear port on my Edelbrock 1406 Carburetor but can't find the fitting to make use of the port.
I am referring to the large diameter port intended to be used for PCV vacuum. The carb only came with a plug and needless to say the good folks at autozone have been less than helpful.
Considering this is a vacuum fitting and thus vital to my motor not sucking terribly (no pun intended), I am loathe to use some jacked up fitting I dug out of a bin at harbor freight. Anybody got the part number for this sucker?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Edelbrock vacuum fitting
Is the plug a screw in type metal plug? If so, I'd remove it and see if I could match up threads/pitch at local Autozone.
If it's on the back, it's not for PCV, it's for brakes. PCV is large center port in the front.
Otherwise might try checking with Edelbrock. www.edelbrock.com
What's funny is autozone doesn't even CARRY just plain 'ol screw-in hose barbs. The only one I could find was for a gas line and it was too big and suuuper long.
I guess I'll wander down to home depot or something and see if i can find a brass hose barb to use.
Also, tried the edelbrock site, no dice. Thanks anyway though
Car: 1992 RS
Engine: Carbed 350
AZ has them - so does Advance. They are behind the counter is a drawerset - you have to get one of the counter people to ley tou go through them behind the counter.
theshackle
Sep 17, 2020 08:26 AM
86IROC112
Aug 17, 2015 02:00 PM
