AIR FILTER HELP!!
Car: 84 trans am
Engine: 305 carb
AIR FILTER HELP!!
I need a air filter 1 1/2 inches in height to clear my hood to my carb. Any thing out there. i have a rpm performance intake and a 1/2 inch spacer under my carb. THANKS
Transmission: 4L80E/4L80E
When you put the lower part of the air cleaner on the carb, is the part where the air filter sits higher, or lower, than the top of the carb?
If it is higher, that is a "flat" base air cleaner. If it is lower, that's a "drop" base air cleaner.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: AIR FILTER HELP!!
Get a drop base 1.5 or 2" it'll take care of your problem....
http://www.jegs.com/webapp/wcs/store...lter+drop+base
Proform has a 2 1/4" dropbase filtr bottom , check it out....
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I use a 1.5" drop base with my RPM airgap and Holley carb and it Just fits under the stock hood.
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
