dieseling problem :(
Old Jun 8, 2010 | 01:18 AM
redroc33's Avatar
Car: 1984 Z28
Engine: 305 HO
Transmission: 5-Speed
I've had a lot of problems with my car dieseling where it keeps firing even though I've turned it off...is this a carb problem or what? 84 z28 305ho
Old Jun 8, 2010 | 01:33 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: dieseling problem :(
this would be a timing issue... either your base timing is not within specs and or your chain has stretched and needs to be replaced...
Old Jun 12, 2010 | 11:30 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
i had a similar problem where the throttle blade(s) on my carb would stick slightly open after i turned off the ignition, and fuel would get into the still hot cylinders and fire for a couple seconds without spark. (thus the term dieseling)
try cleaning up the linkage. carb cleaner and seafom have helped me more than once
Old Jun 13, 2010 | 12:29 AM
sablemaniac's Avatar
Car: 1982 Trans Am
Engine: LG4
the '84 delta 88 i used to have before i got my t/a had that problem. the timing was way off on it. i just shut the car off in gear and it wouldn't diesel.
Old Jun 15, 2010 | 06:24 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
I had the same problem (355 HO 10.3 CR) so what I did was to back out the idle speed adjustment screw all the way so the throttle plates were compleatly closed (double return springs) and added another solonoid (like A/C) to the carb to regulate the idle speed. When I shut off the engine the idle speed solonoid looses power and the throttle plates closes compleatly. NO more dieseling
Auggie
Old Jun 15, 2010 | 06:28 PM
Auggie's Avatar
Oops, forgot the pic!
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
