Lets talk PVCR's
Old Jul 3, 2010 | 12:03 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Lets talk PVCR's
I had my car to the track last night. I was watching the O2 readout on my second pass and it was showing dead lean. Pulled a plug and it was real white. In the end, I ended up going up 9 jet sizes in the primary side only. The car ran better. Now, however, my cruise is real fat (as would be expected). I think what I wasn't to do is up the secondary jet 2 sizes and enlarge the PVCR's on the primary to make up another 5 jet sizes. How much do I need to enlarge the PVCR's to accomplish that? I have read roughly .003" increase is equal to 2 jet sizes when you are less than 80 jets. Anyone have any experience doing this?? Does my plan of attack make sense??
Old Jul 5, 2010 | 07:15 PM
pancherj's Avatar
Car: 1990 IROC
Re: Lets talk PVCR's
Okay, drilled my PVCR's out to .061". They were .055" stock. I also upped the rear jet to an 80. Now my split between the primary and secondary jets is 70/80. If it is a little lean under full throttle, I will just up the primary jets.
I had no complaints about my BG Mighty Demon until now. The stock jets were in so tight that I had to use a pair of vice grips to get them out. Also, the slots in all 4 jets were destroyed by whomever tightened the jets at the factory. That was ridiculous!!
Old Jul 6, 2010 | 12:18 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
What made you increase just the primary jet Jeff? Tuning for WOT I like to start at factory number and split and move both primary and secondary in equal steps till the WOT comes around. Say 76/83 and you end up with 80/85. Then lean out the primary side to get a clean cruise. Then correct the PVCR to bring the WOT back in line.
Sucks about the jet install. I hear BG has improved but I haven't bought a product since my one and only Demon I still run. Maybe I got a wednesday carb...
Old Jul 6, 2010 | 01:07 PM
pancherj's Avatar
Car: 1990 IROC
I only messed with the primary because of time (between rounds). I like the 70 jet in the primary. It seemes to cruise just a tad fat (based on my narrow band O2 sensor). What you suggest above is what I am shooting for. I only emlarged the PVCR's enough to cover 4 jets. I want to fine tune next time at the track and see if I should go more or live with what I have.
All in all, I have been pleased with the carb. I didn't have any issues with junk in the carb. The jets...maybe someone at the factory has been lifting too many weights or arguing with a spouse!!
Old Jul 6, 2010 | 01:13 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Jeff,
Sounds good. Just a lil scary when I first read it! I like the plan. I wish I could get to the track that often....
Old Jul 6, 2010 | 06:34 PM
pancherj's Avatar
Car: 1990 IROC
I wish you could too. I wish I could get there when the DA isn't 3000'!! I want to run in the 11's again bad with my stock short block L98 before it finally blows up.
Linson
Oct 24, 2025 02:00 PM
gixxer92
May 18, 2017 11:20 AM
the_hamturdler
Sep 30, 2015 12:50 PM
ndndndnd
Sep 28, 2015 08:00 AM
fasteddi
Sep 10, 2015 09:32 AM
