car runs REALLY rich. what to do?
Old Jul 10, 2010 | 12:00 AM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
just rebuilt my carb and now my car runs really rich and i have to hold the gas and the break at a stop after it gets warm, or else when i push the gas it almost dies, or does die, then its a pain to start after that. it smells alot like exhaust and gas fumes inside the car, my plugs foul out, and it is always putting out a blackish blue cloud.. i took the carb apart over and over again and re checked the float and needle. it seems like nothing works. what should i check? ive been having this problem for a long time now, it makes the car not so enjoyable to drive anymore
Old Jul 10, 2010 | 11:45 PM
DoubleV's Avatar
Re: car runs REALLY rich. what to do?
What kind of carb do you have? Did you have this problem before the rebuild too? Was the carb ever rejetted?
Old Jul 11, 2010 | 12:13 AM
Engine: 305 v8
i have the stock q-jet 4 barrel. i didnt have the problem before the rebuild as bad..it was a little off but it still ran really well. as far as i know it was never rejetted, at least since ive had it. also something to add- when the rebuild was done and it ran like crap, i tried to put an edelbrock carb on it. it caught on fire due to the angle of the hose and not being clamped tight, it sprayed right at my distributer..the fire was put out fast, and some vacuum lines were melted, but i replaced as many as i could and got the edelbrock 600cfm carb on. the only problem with the edelbrock was it idled very high, smelled funny when driving, (almost like olive oil) and it had NO power. it didnt want to die though, it ran decent with the edelbrock, just sounded like a 350 and drove like a 4 cylinder. so i put the q-jet back on and now it is so rich idk what to do..buy a remanned q-jet seems like my only option i just want to make sure its not something else before i put out 300$ that i dont have to ebay
Old Jul 11, 2010 | 05:07 AM
DoubleV's Avatar
The reason you had no power was because you had zero timing advance due to you not replacing the CCC distributor with a normal one.
Don't ever buy a 'reman' carb unless you're prepared to rebuild the rebuild. Remans are almost always slapped together junk.
So if you have the stock Qjet on your car then it's a CCC carb. If you're running as rich as you're saying, your Check Engine light should've came on. Did it?
When you rebuilt the carb, did you set the lean stop of the MC solenoid correctly? Did you tamper with the idle mixture screws and/or air bleed? What's your dwell at?
Are you sure you have no vac leaks anywhere?
Old Jul 11, 2010 | 05:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
just buy from a reputiable place
order, bolt on, nail it n smile
http://www.nationalcarburetors.com/
Old Jul 14, 2010 | 08:28 AM
1983Zsled's Avatar
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
A common issue on rebuilt Q-jets is that the needle is held inside the float arm incorrectly which can cause the same issues as a float being adjusted incorrectly. The needle clip should be attached to the float arm from the back side, not from the side through one of the two holes, or not from the front of the carb with the rounded edge. How do I know, because I have had the exact same issue while dialling my q-jet. If everything else is OK float level ect..I'd check this out.
Old Jul 14, 2010 | 10:49 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Floats are also known to get saturated, which makes them not float as well. Result is even though it is mechanically set correctly, it takes more fuel in the bowl for it to shut off the flow.
Is your SES light coming on?
Old Jul 15, 2010 | 11:32 AM
Engine: 305 v8
My check engine light is on but it was on long before this because I accidently messed it up somehow so it wont read codes or turn off.I didn't mess with the idle mixture screws...and I'm not sure how to set the lean stop for the mc solenoid. No vacuum leaks that I have been able to find either.
I COULD be having the problem that 1983zsled says with the needle clip being attached from the wrong side..before the rebuild it was clipped in the holes, but I saw in the directions that that is the wrong way, so i clipped it the way i thought it was supposed to be...but I put it on the rounded edge, so I'll try flipping that around to the back today and see what happens..
I also checked to make sure the float wasnt bad, it seems to be ok. thanks for all the help so far
Old Jul 15, 2010 | 01:00 PM
five7kid's Avatar
Does the MCS click when you turn the ignition on before starting the engine?
Old Jul 15, 2010 | 01:26 PM
Engine: 305 v8
this is going to be a stupid question...but whats the MCS? I havent noticed a clicking sound..I will have to go and check. turn it just as far as i can without starting it right?
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
