carb issues
Old Jul 31, 2010 | 12:13 AM
csimpson1's Avatar
Car: 1984 Black Trans Am
Engine: 350 bored .030
Axle/Gears: Stock. Wanting up grade
carb issues
I was told by a mechanic that i had a major vacuum leak, but i cant find a vacuum leak anywhere. When i put my hand over the whole carb it idles alot better, like the whole car runs smoother. the number 2 cylinder isnt firing, so i think the carb is definitely messed up. any and all advice is appreciated!!!
84 Pontiac Trans Am, 305, auto trans, edelbrock 600cfm carb
Old Jul 31, 2010 | 09:57 AM
adams86z's Avatar
Car: 1986 z-28 hardtop
Engine: 355ci w/nos cheater
Transmission: th-350 3300 stall
Axle/Gears: 7.75in 3.70s
Re: carb issues
you can find vacuume leaks with propane, just be carefull you dont have any plug wires arcing, small amount of propane from a torch concentrated it suspect area will cause idle to smooth or change. ive used flammable brake clean although addition caution must be taken not to set it on fire. any major vacuume leaks can usually be heard though.
Old Jul 31, 2010 | 12:01 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: carb issues
I'd get that #2 cylinder firing first, then worry about any vacuum leaks. Carb might be fine, but you won't know until all cylinders are firing. Vacuum leak is a minor thing, worry about it later.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
