secondaries hanging open
Old Jul 30, 2010 | 06:41 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
there is a black plastic circle thing that is connected to the secondary shaft that holds them closed, i dont know what its called or where to get on because mine broke!!!!!!the black circle is in between the 2 venturies and under the needle rod
Old Jul 30, 2010 | 06:44 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: secondaries hanging open
what kind of carb
Old Jul 30, 2010 | 06:45 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
cc qjet 4 barrel of 86 305
Old Jul 30, 2010 | 06:49 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Sounds like typical q-jet secondary fuel rod cam. Try Holley or Edelbrock. Edelbrock used to make a q-jet repops and they offer some parts. Holley does q-jet remans and they may offer parts as well. PM five7kid and see what he knows. He may just chime in on this thread anyway.
Old Jul 30, 2010 | 06:50 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
ok great thanks alot for ur help i just rebuilt the carb and i want to drive my car lol
Old Jul 31, 2010 | 12:26 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Your not likely to find that part, i tried.Samething happened to me some years back.I was able to crazy glue the two halves together, but eventually it broke again.I ended up taking one from a JY carb.In order to install it though, you have to remove the four screws that hold the butterflies on the shaft(not easy, the screws are center punched).Then pull the shaft out partway & install the replacement cam(thats what its called, btw).There is a return spring, screw & maybe a pin that need to be removed/loosend in order for the shaft to slide out & it only slides out from the spring side.Damn dogchesters!
Also make sure if you go this route, not to install the cam the wrong way or it will not pull the secondary needles up/out
Old Jul 31, 2010 | 08:33 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Depending on what your looking for you can get
a qjet replacement at jegs fairly cheap
a edelbrock for a couple hundred new
a spread bore holley that bolts right up to your intake
and have a good working updated carb
Old Jul 31, 2010 | 05:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
As much as I like the q-jet, tk's advice may be the best route. You may also be able to find a good rebuilder who could take care of it for you.
Old Jul 31, 2010 | 07:13 PM
kent624's Avatar
Car: 86 bird
Engine: LG4
Transmission: A4
i would love to get a new one but i dont have the spare $300 for it so thats why i just rebuilt mine and i cant find any at the JY because other people beat me to it
Old Jul 31, 2010 | 11:07 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Almost any rochester will use that cam.Even the 2 barrel version & also the pre ccc units.
83RDRACR
Mar 26, 2016 08:13 PM
sreZ28
Oct 22, 2015 08:21 AM
racereese
Oct 10, 2015 09:39 PM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
