Fuel pump question
Old Aug 15, 2010 | 09:04 PM
spaigo's Avatar
Fuel pump question
I was checking out my fuel pump in my 305 87 iroc, there are to lines for fuel to be pumped out of it. Well one of the lines is stopped with a rubber cap and the other runs up by the carb and is Yed off to first and secondraies.
Would car run better if i ran a second line to the carb? or does it not matter. I am also having problems with the secondary float getting fuel could this be causeing it?
I know i am a newbee but please help
Old Aug 16, 2010 | 11:07 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel pump question
Stock there should be 3 fuel lines, 1 runs to the charcoal canister, 2 is a feed line to the carb, 3 is the return line back to the tank. Are you running a stock carb or aftermarket? Can you get us a pic of this?
Old Aug 16, 2010 | 11:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's no line to the charcoal canister on a stock pump.
How is the rubber cap held on?
Old Aug 16, 2010 | 12:03 PM
Car: 1992 RS
Engine: Carbed 350
Yeah, no charcoal canister line on the pump itself, sorry
Old Aug 16, 2010 | 06:11 PM
spaigo's Avatar
It is an aftermarket summet 600 carb... it is a rubber cap can't think of what it is called but u screw it in and the ring gets bigger and smaler... the fuel pump to my knowlage is stock
Old Aug 16, 2010 | 06:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, the capped line is a little smaller than the one running to the carb?
Old Aug 16, 2010 | 06:27 PM
spaigo's Avatar
Yea the caped one is smaller
Old Aug 16, 2010 | 06:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the return line to send excess fuel back to the tank. With that capped, the internal regulator in the pump can't function and you're getting full flow up to the carb and it's flooding.
Old Aug 16, 2010 | 06:46 PM
spaigo's Avatar
Yea just check and you r right found line it should run to
Old Aug 16, 2010 | 06:53 PM
spaigo's Avatar
The quiesten then I wanna know is why didn't who ever hook itdidnt do it right
Old Aug 16, 2010 | 07:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe $5 of 1/4" fuel hose is too much for some people to spend. More likely it was removed under the misguided assumption that it was something to do with "emissions".
Old Aug 16, 2010 | 08:11 PM
spaigo's Avatar
I went and got a hose for it, carb is off but still runs way better then it did before... thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
