1406 acceleration problem
Old Aug 17, 2010 | 09:35 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
we got my car out for a test run today, and at WOT there's hardly any acceleration at all, if it's just sittin in park it revs up great, but not when under a load, i figured something to do with the secondaries maybe? any help would be great!
Thanks,
Kohl
Old Aug 17, 2010 | 10:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1406 acceleration problem
How is the carb set up?
Old Aug 17, 2010 | 10:17 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
The carb sits on a jegs aluminum inatake, electric choke hooked up, mr gasket 4 psi pump, and signature series air cleaner. igniton is hei vacuum adv.
Old Aug 17, 2010 | 10:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
New, used or rebuilt? Idle mixture and speed settings? Rods and jets? Choke open or closed when you try this?
Old Aug 17, 2010 | 10:45 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
it's a remenufacture one from summit, and its on the stock setting, and choke was open when we took the air cleaner off
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
we did adjust the idle mixture some
Old Aug 17, 2010 | 10:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What about the distributor, how is it curved?
Old Aug 17, 2010 | 10:54 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
it is about 12-14 btdc
Old Aug 17, 2010 | 11:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
12-14 degrees base timing... and the advance?
Old Aug 17, 2010 | 11:09 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
i do not remember, we messed with the timing today cause it was starting hard, now it is prolly different or off, and i dont have a timing light..
Old Aug 17, 2010 | 11:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Where did this distributor come from?
Old Aug 18, 2010 | 05:18 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
its the summit hei distributor i got from them.
http://www.summitracing.com/parts/SUM-850001R/
Old Aug 19, 2010 | 06:46 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
So the stock settings of a 1406 are pretty lean. Try buying a 1487 carb rebuild kit and re-tune the carb. If you got the book for the carb with it, (you mentioned it was a reman'd carb, did you still get everything with it?) it will have a chart for the 1406 and it gives you the rods and jets to change for better performance or milage. I re-tuned my 1406 and it really helped.
Old Aug 19, 2010 | 06:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Be sure to read the Edelbrock manual from beginning to end, and then follow the detailed instructions inside for the tuning process as well.
Old Aug 19, 2010 | 07:26 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
alright, i will re-read it and see if i come up with something
Old Aug 19, 2010 | 08:29 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
alright i just finished reading the manual, I understand the operation tons more, but i dont understand why you cant see the secondaries open up during WOT while your looking at it under the hood sitting still? but it seems like i am too lean in the power mode... if i go up 1-2 stages in power should i go up in cruise mode also?
Old Aug 19, 2010 | 08:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Because there's not enough demand for air to make the secondary air valve above the secondary throttle blades open.
So you've done already done the test runs that the procedure described?
Old Aug 19, 2010 | 08:55 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
no i have not done any test yet, its just while you driving and you stomp on WOT there's hardly anything, the motor barely rev's up. so figured when its at WOT or power mode it must be to lean, or the secondaries are not functioning at all.
Old Aug 19, 2010 | 09:11 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
i think i found a solution, if i am using a dual plane inatake and i dont have the adapter for the carb, could that be blocking the the secondaries butterflies from opening???
Old Aug 19, 2010 | 09:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, but which intake are you using?
Old Aug 21, 2010 | 05:21 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
my inatke is a dual plane spreadbore aluminum from jegs, they dont make it anymore. so my secondaries should open. well we took the carb off and there was this clip that kept the secondaries from openin on the side. so we took it off and now they function like mechanical secondaries. we put the carb back on and tried it, made a little difference but still doggy.
so then we changed carbs, we stuck on a Qjet, which ran just as good. but still no extreme change. we think it may be the cam specs now, just i dont know a whole lot about whats good and not good.
here are the cam specs
Advertised Duration 282° 292°
Duration @ .050 "224° 234°
Valve Lift w/ 1.5 Rocker Arms 0.4650 .488
Valve Lift @ Cam 0.3100 .325
Max Lift Angle 109° 119°
Lobe Separation 114°
Cam Timing @ .050" - Opens3° ATDC56° BBDC
Cam Timing @ .050" - Closes41° ABDC-2° BTDC
Old Aug 21, 2010 | 06:51 PM
Hubes's Avatar
Car: 85 Z28
have you confirmed the secondaries are opening? with the engine shut off and the air cleaner removed open the throttle all the way and push the secondary air valve open, this way you can see the secondaries. also have someone sit in the car and press the pedal to the floor and confirm that its opening the throttle all the way. simple things i know, but sometimes thats where you gotta start.
Old Aug 21, 2010 | 07:14 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
yes, the secondaries are opening for sure. we checked them
Old Aug 21, 2010 | 11:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Was the choke open or closed when you tried it?
Old Aug 21, 2010 | 11:41 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
umm i dont remember really.
Old Aug 21, 2010 | 11:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Put the link back on, and then try it both ways... once with the choke open, and once with it closed.
Old Aug 21, 2010 | 11:56 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
i just look over the 1406 360 degree view on summit and it sappears the link gets puched down when the choke is fully open, and then allows for the secondaries to work.so now that i have tested it with working secondaries the issue is most likely else where, unless it's just that lean....
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
