AN fuel lines
Old Sep 8, 2010 | 03:15 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
AN fuel lines
I am switching from tpi to carb on a 90 camaro. And I would like to keep the original fuel lines in case I ever want to go back to tpi. Does anyone know what type or size fitting and lines I can use to go from the original fuel lines to a fuel pressure regulator ( Mallory 4309) and from the regulator to an edlebrock carb? Thanks
Old Sep 8, 2010 | 03:42 PM
miatanut5's Avatar
Car: 1986 IrocZ
Engine: carbed 383
Axle/Gears: 10 bolt 3:23
Re: AN fuel lines
I used summit number 220009. It contains both fittings which adapt the tpi fuel lines to AN. I believe Accel makes them also.
Old Sep 8, 2010 | 09:46 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: AN fuel lines
Thanks Miatanut5 I will try that.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
