fuel line/ pressure regulator/ carb question
Old Oct 4, 2010 | 06:39 PM
crystal383's Avatar
i'm putting together my first carb setup. i know to run the feed line to the pressure regulator and then to the carb. but i don't know where to hook the return line up to.
i'm running a standard holley pressure regulator. p/n #12-803. it has three pots. two are stamped, "out" and one is stamped, "in". The instructions say to run the feed line to the "in" port. And run the out ports to each carb if you're running a dual carbs. and if you are running one carb to plug the extra "out" port.
i want to know where if i plug the extra port, where do i run the return line to?
Old Oct 4, 2010 | 07:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel line/ pressure regulator/ carb question
That's a deadhead regulator, you can't use it with a stock pump.
Old Oct 4, 2010 | 07:52 PM
crystal383's Avatar
i don't have a stock one. i have an aeromotive ss pump. http://aeromotiveinc.com/products-pa...l-pump-38-npt/
Old Oct 4, 2010 | 09:46 PM
crystal383's Avatar
do i have to use one with a return on the regulator?
Old Oct 4, 2010 | 10:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not with that Aeromotive pump, but there are advantages to doing so.
Old Oct 5, 2010 | 03:02 AM
crystal383's Avatar
so do you think if i got something like this would that work?
http://www.summitracing.com/parts/HLY-12-803BP/
Old Oct 5, 2010 | 11:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That should work.
Old Oct 5, 2010 | 10:42 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
i would recommend using a bypass type regulator.
Old Oct 6, 2010 | 09:38 PM
crystal383's Avatar
isn't that what the one is i put up the link to?
Old Oct 7, 2010 | 12:21 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The 12-803BP is, yes.
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
