carb leak
Old Oct 8, 2010 | 03:54 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
carb leak
I was pouring gas in the carb and a couple seconds later I saw drops falling onto the intake. It's on the driver side. It looks like it came out of these springs because they are wet:
Old Oct 8, 2010 | 05:02 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: carb leak
How much did you pour, & what carb is it??
JUST a guess, but sounds like you didn't open the butterflies when you did it, & the gas found it's way out.
What problems led you to do it?
Old Oct 8, 2010 | 05:15 PM
0pyders's Avatar
Re: carb leak
whats the butterflies, is that the thinner part that opens.
Old Oct 8, 2010 | 05:27 PM
0pyders's Avatar
Re: carb leak
It's a quadrajet.
here's what it looks like without me touching anything:
I noticed this lever doesn't have anything attached to it, does something go there?:
Old Oct 11, 2010 | 10:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb leak
Why would you pour gas into the carb anyway?
Old Oct 11, 2010 | 12:22 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: carb leak
As already asked the question is if the butterly's were opened. The poster meant was the throttle cracked open a little. If not the gas would sit on the throttle plates (butterflies). Then it will find a way out. This is usually the throttle plate sahfts as they are not actually sealed. a slow seep is normal but running out would indicate a worn shaft or shaft bore in the baseplate.
Old Oct 11, 2010 | 11:42 PM
0pyders's Avatar
Re: carb leak
Thanks guys, It's fixed. I just poured gas in the wrong spot. :/
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
makaveli09
Sep 15, 2015 10:43 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
