TV Cable?
Old Oct 10, 2010 | 07:00 PM
lackid20's Avatar
Car: 1985 Z28
Engine: 5.7L TPI
TV Cable?
I want to do a swap from TPI to carb... I've been able to find all the info I need to make the swap. I was looking at my car tonight and I dont see the TV cable. I could be wrong... but one is the throttle cable and I think the other is the cruise. The car drives fine... and shifts ok, although it shifts hard but the guy I bought it from said he put a shiftkit in it. Please help me out... is it even possible to not have a tv cable? The car is an 85 Z28 that somewhere along the way had the engine swapped to a 87 or newer tpi 350 and 700r4.
Old Oct 10, 2010 | 07:21 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Re: TV Cable?
The other cable is the TV (Detent) cable. Do you have cruise on your turn signal switch?
Old Oct 10, 2010 | 07:28 PM
lackid20's Avatar
Car: 1985 Z28
Engine: 5.7L TPI
Re: TV Cable?
Yes I have cruise on the turn signal switch. It does not work though. I saw a bunch of pictures on here of other peoples tv cable and they all look different than mine. They have a long metal bracket on the end of the cable... and mine doesn't. That's why I thought something was fishy.
Old Oct 10, 2010 | 07:39 PM
texascat2's Avatar
Re: TV Cable?
My TV cable looks a little different on the cable just behind the bracket for both cables. I haven't seen a cruise set-up on one yet. When I bought mine from a very close friend and original owner, I asked him why he didn't get cruise on it, he said real hot-rods don't have cruise!
Old Oct 10, 2010 | 07:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: TV Cable?
YOUR TV cable is the one on the top in that pic (on the top of the linkage, not the bracket). In your pic, you are showing the TV cable and the throttle cable.
As I have read, you'll have to change your TV cable out for one from a TBI or a carbed car - something about the length on the TPI cables.
texascat2's Avatar
Re: TV Cable?
The 700 R4 won't shift right with out the TV cable. From your picture the motor looks stock. Mine has shifted hard from first to second since it was new. After it warms up it's not quite as hard but firm.
Old Oct 10, 2010 | 07:58 PM
lackid20's Avatar
Car: 1985 Z28
Engine: 5.7L TPI
Re: TV Cable?
Thanks for the help guys. I didn't even know what a tv cable was until about 2 days ago. How hard would that be to change to one for a carbed engine?
Old Oct 10, 2010 | 08:01 PM
Car: 1992 RS
Engine: Carbed 350
Re: TV Cable?
On the other end, the cable goes into the top of the tranny on the pass side - there's a hook and a loop that connect (I just don't remember if the hook is on the cable or if it's in the tranny). There is one screw that holds it to the top of the tranny - it's an easy swap.
Old Oct 10, 2010 | 08:06 PM
texascat2's Avatar
Re: TV Cable?
Camaronewbie, you have the TV-easy link? I'm on a new PC, lost all my short-cuts.
Old Oct 10, 2010 | 08:52 PM
texascat2's Avatar
Re: TV Cable?
Here's a link with some good info.
http://www.tvmadeez.com/
Old Oct 10, 2010 | 09:32 PM
lackid20's Avatar
Car: 1985 Z28
Engine: 5.7L TPI
Re: TV Cable?
Thanks for the link, very informative!
Old Oct 10, 2010 | 09:44 PM
texascat2's Avatar
Re: TV Cable?
Not a problem, took me awhile to find it. One of the other members showed it to me. "Knowledge is Power"
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
