how do i get the most out of my ccc Q-jet?
Old Oct 20, 2010 | 03:46 AM
isr85-T/A's Avatar
Car: 1985 Pontiac Trans Am
Engine: 4 bolt main 350ci. LG4,
Axle/Gears: stock
Is their anyone who can give me some tips on how i can tune my ccc q-jet? Im looking to get a little better response.
Old Oct 20, 2010 | 07:05 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: how do i get the most out of my ccc Q-jet?
Welcome to TGO.
Tuning the ccc-qjet requires a dwell meter or scanner. The goal is to get the Mixture Control Solenoid (MCS) dwell near 50% at idle. The MCS controls the amount of times the primary rods are in the jets, restricting fuel flow. At 50% dwell the system has the most room for adjustment each way, rich or lean.
The system requires input from several sources including the distributor, Vac sensor, O2 sensor and TPS.
There's a tech article here on adjusting the AV tension and choosing secondary rods and hangers. The secondary side is the same as any other mechanical qjet.
Are you experiencing specific problems?
Old Oct 22, 2010 | 02:25 AM
isr85-T/A's Avatar
Axle/Gears: stock
my car is just getting a little slugish and im guessin my car needs to be tunned to get the most out of the 350 in it.
Old Oct 22, 2010 | 09:16 AM
naf's Avatar
naf
Some good stuff here:
https://www.thirdgen.org/forums/carb...its-greek.html
If you haven't yet replaced the cap/rotor/plugs I'd do that first. They're routinely replaced items. Otherwise let me know where you're at and/or any specific q's you have and I can help out.
69GTOby
Apr 18, 2016 02:34 PM
2QUIK4U
Aug 26, 2015 04:40 PM
Street Lethal
Aug 13, 2015 08:28 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
merf23
Carburetors
Dec 17, 2000 08:54 PM
