carb for tpi swap-and im stumped?
Old Nov 16, 2010 | 10:00 AM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
i am new to the forum,but not to hot rods or 3rd gens,and i just picked up a 86 z28 that the former owner was about 3/4 of the way through a carbed 350 swap.the issue im having is im pretty sure the fuel regulator is incorrect.if i drive for 10 or 12 miles,the car stalls like its out of fuel,and if it sits for 10 or 20 seconds it will take right back off.i unhooked the fuel line,ran a extra piece to a 5 gallon gas can,jumpped the underdash connecter and it filled up the can in about 5 minutes,so i think the pump is okay.the regulator that is on the car is a holley 12-704 with the return line hooked to the 2nd outlet,and the other outlet going to the carb.does it sound like a screw up on the previous guys part? thanks for any help anyone can give me,if i cant figure it out,ill pull the electric pump and run a mechanical one.
Old Nov 16, 2010 | 10:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb for tpi swap-and im stumped?
He's tried to use a deadhead regulator in a bypass application. Try a Holley 12-803BP or a Mallory 4309.
Old Nov 16, 2010 | 10:21 AM
andy74's Avatar
i figured that was the issue,just never fooled with an electric fuel pump before-im 36 years old but lost in time when mechanical fuel pumps,carbs and sometimes even point ruled! my 63 buick wildcat is so much simpler !thanks
Old Nov 17, 2010 | 07:29 AM
andy74's Avatar
would the dead head regulator cause the car to act like i described? if so,why?it acts like it ran out of gas,is that a fail safe on the fuel pump,or something else?
Old Nov 17, 2010 | 03:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The flow test sounds reasonable. The dead-head reg will cause the fuel pump to overheat, which may shut it down. Then, it'll restart after given a chance to cool and recover.
Old Nov 17, 2010 | 03:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not actually deadheading, though. It's a 2 output pump, with one output up to the carb and the other one just straight back to the tank.
Old Nov 19, 2010 | 07:42 AM
andy74's Avatar
i have been working all week,but im going to put some garage time in tonight and tommorow,ill let you know how i make out-i got the holley by pass regulator in the mail last night.my oldest son works for advance auto parts so with his discount it only cost me 60 bucks-hope it works out,im tired of driving my ex wifes riviera!
Old Nov 19, 2010 | 10:00 AM
five7kid's Avatar
(But you meant 2 output reg, right?)
Old Nov 19, 2010 | 10:02 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, regulator, not pump. I think the return is just stealing most of the flow sometimes.
Old Nov 19, 2010 | 11:06 AM
andy74's Avatar
thats what i think also,the 2nd output sends to much fuel back to the tank
Old Nov 22, 2010 | 07:45 AM
andy74's Avatar
swapped the new regulator and ran some new fuel lines over the weekend,drove about 30 miles last night,and drove to work this morning,seems to be running like its supposed to now! thanks for your input everyone
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
