Do i have an 800 CFM Quadrajet?
Old Nov 21, 2010 | 10:44 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
I was at the Junkyard looking at the New arrivals (I'm usually at the Junkyard) and saw a 1986 Camaro. I was thinking YES! Fresh Parts! In the cargo area, i found two Quadrajets. One looked like it was pretty well used and was the Electronic kind (Yuck, Blah), and the other was Non-Electronic. In addition, it looked like it had been professionally rebuilt recently. In fact, i doubt that it was on an engine for long if it had been after the rebuild. At the U-Pull-It yard, Carburetors are $28 no matter what they are, so i figured i would gamble. Since then i have determined that it's a 1979 Model.
Serial Numbers are:
17059205
1139 CBD
It has a Hot-Air Choke
There's a Paper sticker attached that reads:
UREMCO
Remanufactured
3-3686
01/23/09
I have not tried this thing on my car, so i don't know if it's good or not. Do you think i should try to rebuild it before i try it?
Is this 800 CFM?
Attached Thumbnails Do i have an 800 CFM Quadrajet?-img_20101121_222545.jpg   Do i have an 800 CFM Quadrajet?-img_20101121_222652.jpg   Do i have an 800 CFM Quadrajet?-img_20101121_222818.jpg
Old Nov 22, 2010 | 12:20 AM
t.p.engineerin's Avatar
Car: 88 iroc/87 k10 pickup
Engine: 357 carb/305 tbi
Transmission: 700r4/700r4
Axle/Gears: 3.42/3.42
Re: Do i have an 800 CFM Quadrajet?
i would buy 2 carb gaskets put that carb on see how it runs and go from there no sense in going through the money time and trouble if there is no need especially how good it sounds in your discription and if it dont run good you can put your old carb on
Old Nov 22, 2010 | 12:40 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not likely to be 800 CFM. Originally it looks to have been from a 79 GMC pickup, but there's no telling how it's been rebuilt.
Old Nov 22, 2010 | 12:41 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, GM stopped using the hot air choke in '74, so if its a hot air choke, its a '74 or earlier unit. Also, only the very early Qjets (like mid 60s) were 750cfm units. All the later ones were 795cfm, with a few being 850cfm on the really big motors like the 500ci Caddy for example.
Old Nov 22, 2010 | 12:43 AM
383 Power's Avatar
So, then, the lump i'm seeing in the Primary is not the one i'm looking for? I've read that if it has a lump in the Primary it's the 800CFM, but i'm not experienced at Quadrajet ID so i wanted verification.
Old Nov 22, 2010 | 12:46 AM
383 Power's Avatar
Do you guys suppose this would be a decent carb for my 305? $28 was hard to pass up. Does it have potential to put atop a 383?
Old Nov 22, 2010 | 12:52 AM
383 Power's Avatar
More Photos
Attached Thumbnails Do i have an 800 CFM Quadrajet?-img_20101122_004939.jpg   Do i have an 800 CFM Quadrajet?-img_20101122_005001.jpg
Old Nov 22, 2010 | 01:52 AM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
I had hot air choke on my 83 truck. I'm fairly sure it was 795 cfm. I say slap it on and try it
Old Nov 22, 2010 | 03:00 PM
383 Power's Avatar
It works! the Carb is a BEAST! it idles nice and smooth and delivers fuel like a champ.
Old Nov 22, 2010 | 03:47 PM
Good to hear
Old Nov 22, 2010 | 03:50 PM
383 Power's Avatar
Already have it sold to a buddy of mine that was needing a carb
Old Nov 22, 2010 | 04:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's not it... look from the top, not the bottom.
Old Nov 22, 2010 | 05:28 PM
383 Power's Avatar
Thank you. I'll tell my buddy. He should know since he just bought the carb from me. It's sitting on his 79 GMC 4x4 right now. He seems pretty pleased with it's performance. I wonder if 50 CFM is going to make a difference to him. If he doesn't want it, i'll still be glad to take back a good working Quadrajet. Thank you for helping me.
randy210
Oct 15, 2015 03:43 PM
okfoz
Oct 13, 2015 02:19 PM
Dragonsys
Sep 25, 2015 03:51 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
